Apple iPod nano Logo
Posted on Jul 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Language change I have a 4GB Nano. I know nothing about how to work it. I changed the language to an east european one by mistake. How do I change it back to english. I am baffled. Gerry
Anonymous
Level 2:
  • Expert 38 Answers
  • Posted on Jul 20, 2008
Anonymous
Expert
Level 2:
Answers
38
Questions
Helped
7097
Points
104
Turn ipod on and hold the menu button for 1 second. language change - f57f6a7.png  Scroll down 4 options until you get to settings.  Scroll all the way down to language which is 2 from bottom. From here you should be able to find the language you want.  English is normally the top option.  hope this helps ;)
I need to change the settings from chinees to english
  1. Scroll down to the last menu item, but don't select it.
  2. Scroll up one menu item to what should be Settings. Then press the Center (Select) button to select it.
  3. Scroll down to the last menu item, which should be Reset All Settings, but don't select it.
  4. Scroll up two steps to what should be the Language. Press the Center button to select it.
  5. Select your preferred language from the list.
https://support.apple.com/en-au/HT201650
1helpful
HP Photosmart Premium All-in-One Series 309a use of Printer Cartridges #364 (Europe) instead of #178 (Middle East). I brought my printer when I lived in the middle east approx 18 months ago. In the middle...
Hi
Well it is nothing but to change the region of the printer. hence remove all the cartridges and remove the power supply first.
1. Hold # & 9 key on the keypad
2. Connect the power back to the printer
3. It will say NVRAM init.
4. It will ask for the Region select what you want.
5. And continue to work
OR
Goto setup menu in printer and change the region.
Regards
2answers
My nokia N70 phone language been changed by mistake into some european language, again i am trying to change it into english but due to the european language i don't know which buttn to press to do the...
Hello Swetha.
Can you do a screen-scan on a flatbed scanner of a page showing the language?
Then the word equivalents can be looked up to help you navigate.
Otherwise post a few of the words which may give us 'le clue'...
Language on ipod nano
It's resolved. Thank you. All I had to know is the dutch translation for ''settings'' since all the different sections were all written in that language.I set the language back to ''English US''
2answers
Changed language to french!
Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
1helpful
2answers
Can't put my ipod back in english
try to reset the i-pod.then if u have symbols then go to settings and change language... or buy a chinese to english book
Iopd wheel not responding
Send it in. Call apple or go to  https://selfsolve.apple.com/GetWarranty.do
first, press the menu button on the click wheel until your screen goes to the home screen (main menu). you will know you're there when the screen doesn't change anymore. select Reglages, then Langue, and finally English.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
