Question about Compaq Presario S6500NX (DQ181A#ABA) PC Desktop
When i start the pc it gives me one short beep and one long beep that keeps on repeating. Every once in a while the pc doesn't beep and i get a flickering distortion like falling snow just in color(black, red & white) The computer was never tampered with so everything inside the case is well connected, and untouched!
    Genius:
  • 1,288 Answers
Several possibilities here:
Powersupply not working correctly, test with another PSU to eliminate this
Ram issue, Ram is failing under load, download a copy of memtest and run it to check for ram related issues
Video card fault. If possible, try another video card and see if this resolves the issue
Other faults and these are remote, are that the CPU heatsink is loose, the fan is working intermittently
(check and run with the side panel off), or in extrame circumstances, there is a fault on the motherboard
Posted on Jan 29, 2011
6ya staff
SOURCE:
Windows loads up bios beeps once repeatedly
Make and model of laptop will reveal bios error codes
Aug 17, 2015 | Computers & Internet
Acer aspire zs600 Has Black Screen and Beeps 6 times, then repeats beep...
You might want to start in the safe mode. Right after you reboot your computer keep pressing f8 and it should start in safe mode. Once there you could then possibly see if you can solve the problem.
Good luck,
Marty
Jul 15, 2014 | Acer Aspire ZS600-UR308 - Core i3 3220 3.3...
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Problem for HP HP Pavilion dv2000 15.4" Notebook Laptop PC The power is OK but I get 1 long beep and 2 short beeps when switching on, the screen remains blank and no activity on the laptop
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 13, 2009 | HP Pavilion dv6000z Notebook
Sony vaio athlon 2800+ started beeping,one long beep lights flash
listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
Jan 24, 2009 | Computers & Internet
Compaq Presario S6500NX (DQ181A#ABA) PC Desktop Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
