Juki MO-655 Mechanical Sewing Machine Logo
Posted on Jan 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I THREAD THE JUKI MO 2416N - Juki MO-655 Mechanical Sewing Machine
TCHNICAL SUPPORT FOR JUKI-JACK-PEGASUS
Level 2:
Scholar:
  • Juki Expert 180 Answers
  • Posted on Mar 13, 2011
Juki Expert
Level 2:
Scholar:
Answers
180
Questions
Helped
88203
Points
312
HI THERE
CAN YOU PLEASE EMAIL ME ? I CAN SEND THREADUNG DIAGREM FOR THAT MODEL.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
[email protected]
Juki Serger - MO-50e thread will not move out of the machine and continues to tangle under the needles. Please help! The machine worked beautifully for a few hours and now it is a really expensive p
I have had this happen, check your tension on that thread and check the thread thickness. Tofix mine I recall changing both,and I think it was the thread thickness in relation to the tension
1helpful
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
1helpful
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
2helpful
THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
3helpful
I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
