Check your manual. You can download it here if you can't find your.LG DLE2532W Dryer Owner's Manual
FileName: l0310453.pdf
UNPLUG THE DRYER FIRST!
Access on these dryers are not from the back. (There are tabs between the top and front panel). So take something thin like a puttyknife and slide it between the top of the dryer and the front panel about 3in from sides....there will be one on each side. Push in to release the tabs. The top will raise. Unscrew the 2 screws at each top front corners. Pull the front panel toward you and unplug the door switch. Remove the front panel and take the screws from roller and duct panel and remove from latches. You will have access to everything now.
