Question about KitchenAid KCMS145J Microwave Oven
Latch opener spring broken wont open door - KitchenAid KCMS145J Microwave Oven
    Sergeant:
    Champion:
  • 342 Answers
You can buy a new door spring through KitchenAid by calling For more information on warranty replacement, please call 800-541-6390
that should solve the issue if not feel free to contact me.
Posted on Jan 29, 2011
6ya staff
SOURCE:
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
Door wont open
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Microwave oven door wont close
Most microwaves will have a spring loaded latch on the door. The likely issue is the clip for the spring has broken. Unplug it, put it on the benchtop and pry open the inside of the door. It's usually a soft plastic cover that with a gentle persuasion from a flat screwdriver will come off. Start above the latch and pry open as much ad needed. Locate the spring at the bottom, open up one of the fixing loops on the ends with long nose pliers and attach it to a fixed spot around the inside of the door. There are usually metal ribs inside the door and attach the other loop to the base of the latch
Mar 09, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
220 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
