Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I do not have an internet connection when using my router...how do I resolve this?
  • D-Link Master
  • 4,338 Answers
Perform a D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 29, 2011
6ya staff
SOURCE:
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I have no internetconnection with my ps3. I have error 80028ea6 Who can help me?
Good day. If your ps3 is not connecting to the internet. Try to do this steps:
1. Check all of the wire and cable from modem to router.
2. Make sure all cables are tight
3. Try to reboot your equipment on this sequence, modem - router - ps3
If these didn't resolve your issue you need to contact your Internet Service Provider to check your connection. Possible the modem is not getting any signal. If your modem is working good then contact the router support to check the settings with your router. But usually your Internet Service Provider will be able to resolve this issues. Hope this information will help you in resolving your connection problem. Have a great day and thanks for using Fixya.
Jun 23, 2011 | Computers & Internet
Cannot connect to Internet via router. works OK when direct connected to DSL modem. Powering off router does not help. port lights flashing very fast on router.
To be able to browse using wifi, the internet (dsl) cable should be at the number 1 port of your router and the other end should be at the modem. No other wires should be connected on the router.
Mar 09, 2011 | NetGear RP614 Router
Cannot connect to internet using this~help!
Hi Friend,
Please follow the steps in order to resolve the issue;
I hope you have a cable internet connection.
1.Make sure the connections are properly fitted as mention below:
The wire coming out from the modem should be fitted into the WAN/INTERNET port of the router. Connect the computer to either of the four LAN ports.
2.At the back of the router there is RESET button, push and hold that button for 30 seconds and then release it.
3.Turn off the router for 30 seconds and turn it on after that time.
4.Type 192.168.1.1 in the address bar of the web browser (Internet Explorer, Mozilla) and hit enter
5.Enter the Username and Password(default password is admin and leave the username blank)
6.Under the setup page make sure "Obtain an IP Automatically" is selected and DHCP server is enabled. click save settings
7.Now Click MAC Address Clone
8.Enable MAC Clone Service and click the TAB Clone
9.Click save settings and turn off the router for 30 seconds and Turn it on after 30 seconds.
I hope this will resolve the issue.
Regards
Chiranjeet
May 28, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can't connect to internet
just try to power down your router for a minute or two then fire it back up again...9times out of 10 this resolves the issue...failing that try re-installing the wireless adapter.... hope this helps
Dec 11, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
No connection to internet (wireless) on laptop
the telephone connection is lacking of your site!! but you can use the MODEM ROUTER, in order for you to able to function the internet..
Aug 25, 2008 | SMC Barricade g SMC2804WBR Wireless Router
Belkin router
check you connections
DSL or CABLE Internet service connect to the routers WAN
Your PC connect to one of the 4 LAN, unless you are using wireless.
test Internet connection by directly connecting the modem to your PC, if that works the above should resolve the problem, unless the router is bad.
hope this helps
thanks for the rating
Jan 07, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
41 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
