Question about ASUS M4A78LTM LE Motherboard
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it will work togather ????
    Scholar:
    New Friend:
  • 43 Answers
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Posted on Jan 28, 2011
Testimonial: "vary good this helps to get it right the first time thank you"
6ya staff
SOURCE:
Ram Memory
What OS are you using? If you have a 32-bit OS, this is the normal behavior. The extra 0.75 GB isn't directly addressed by the OS; it will be used for part of the memory cache. If you had a 64-bit OS, you would either see the full 4GB of memory or have a POST memory error on boot.
For most Windows OS versions, you can check your version by going to the System Control Panel. On XP through Windows 7, click Start > Control Panel. Then go to System and Security > System. If you do not see x64 at the end of the OS title, you have the 32-bit OS. For Windows 8 from the desktop, use the Charms menu (Win+C) or Windows Tools menu (Win+X). Then from Charms, select Settings and then Control Panel. From the Tools, go to Control Panel. Select System and Security > System. Read the line "System Type" in the System section.
I hope this helps.
(My old system could not support a 64-bit OS due to the CPU; I still put in the full 4GB even though it wasn't fully accessible.)
Jul 13, 2013 | Kingston Technology RAM Modules...
Can i put 2x2gb ram in k9vgm-v motherboard
It should specs say:
• Supports Dual DDR II 533/667/800
- 2 DDRII DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 2GB.
Most systems will pick up the 4GB, but Windows 32Bit has a 3GB limitation.
May 06, 2013 | MSI K9VGM-V Motherboard
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
Installed 4 G of RAM. Installed Windows 7. Only 3 G RAM Usable
To recognize more than 3GB of RAM you will need a 64 bit version of the operating system. If you install Windows 7 32 bit (normal for most users) you will only see 3.
You should have both versions of Windows 7 (32bit and 64 bit) on your installation disk. However you will need a 64 bit capable processor to install it. Otherwise 3GB of RAM for a 32 bit operating system is more than enough.
Mar 08, 2010 | MSI PT880 Neo FSR Motherboard
Vista 32 bit is a 32 bit system and can only handle 3 Gigs of ram. Same goes for XP. Doesnt matter if you have 4 6 and 8 the OS can only handle 3
Vista X64 and XP X64 recognizes what memory you have installed in the system.
If your system doesn't support 64bit then your stuck with a 32bit system.
Regards
Jun 18, 2009 | Evga (122-CK-NF68-AR) Motherboard
Problematic recognition of memory
You may try another OS if you think, this is a software problem. please let me know the update with another os like xp ?
May 24, 2009 | Computers & Internet
Black screen and three beeps
your m/boar is now not supporting the ddr which you are putting in, so you have to replace your ddr with Kingston DDR it'll solve the problem
Dec 06, 2008 | ASUS K8V-MX Motherboard
4 GiG memory
Your motherboard doesnot offer dual channel memory architechture and 2x2GB memory is taken in sigle channel mode. Apart from that 32bit Operating Systems don't recognise memory over 3 Gb. So you have the following options...
1. Attach only one 2GB
2. Attach 2GB + 1GB
3. Move up to a 64bit OS with your current 2x2GB memory modules.
Please collect memory module of the same frequency if you consider option 2.
Sep 08, 2008 | Computers & Internet
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
ASUS M4A78LTM LE Motherboard Logo
635 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
