Nokia 2680 Slide Cell Phone Logo
Posted on Mar 30, 2017
Hello! My Nokia 2680 Slide turned off when the battery ran out. Now, after recharging, I'm trying to get it back to work. My problem is that it keeps telling me my PIN were incorrect, and not only that, when I had to enter the PUK, it said I had to enter a new PIN-so the PUK had to be correct, I assume. Whenever I try to confirm the new PIN, I get an error message-and I am not THAT clumsy with the keys. I'm quite lost as for what I should do now, since I got only one try left to enter the PUK, and, more problematicly, confirm a new PIN. Please help me out here, since I believe that this is not a SIM-card problem my provider could help me solve. Kind regards, Oliver Kuenster
5 Related Answers
Anonymous
  • 283 Answers
  • Posted on Nov 11, 2008
SOURCE: PUK code for NOKIA 6020
Your nokia 6020 doesn't have problem. It's your sim card. If you still have your simcard packaging, the PUK code is written their inside it's brochure. Or you can also go to your mobile phone network and ask its PUK code. Or simply buy a new simcard with the same network company. Thank you
Anonymous
  • 30 Answers
  • Posted on Jul 11, 2009
SOURCE: Nokia E61i - SIM Rejcted & asking for PUK Code
If you log onto your companys website under your account and go to the option that says devices you can get the puk code- If you enter in too many numbers it will permanently block your sim card and you will have to buy a new sim card from your cell phone company- they are about $20
CellPhBuddy
Ian
  • 262 Answers
  • Posted on Mar 15, 2011
SOURCE: cant get security or puk
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
Anonymous
  • 77 Answers
  • Posted on Apr 20, 2011
SOURCE: I need the puk code
you can get the PUK Code from service provider.
Anonymous
  • 60 Answers
  • Posted on May 19, 2011
SOURCE: my nokia C3 was blocked by my son now it says
the puk codes can be found on the sim package that you have purchased. check there.
My nokia 2680 slide cell phone is not turning on
better you reset your phone or reinstall the os
Unlock code for Nokia 2680s -2b
Hi, You can get the unlock code for a Nokia 2680 Slide from http://www.simpleunlocking.com/nokia-2680-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 2680 SLIDE
1 - Switch on your Nokia 2680 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2680 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2680 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2680 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2680 SLIDE
4helpful
2answers
Can you still unlock a phone even if it says cannot undo restriction.
If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
You can get the Restriction code here
Theunlockspot.com and Unlock it from Network Lock. Follow the instructions and enter the code correct step by step...
Nokia 2680 SLIDE Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 2680 SLIDE mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2680 SLIDE mobile phone, your phone may get hard locked and sometimes become unusable.
1helpful
Blank screen but phone still works
you need to replace the flex or the ribbon wire of the unit. it looks like this picture955dfca.jpg
Unlock nokia 2680 slide imei no. 354207/03/808101/7
For the best unlock code for your Nokia model mobile,
you can try this site http://www.onlinegsmunlock.com/nokia-2680-slide/rs7wp9/
It has the step by step instructions and easy methods for unlocking your Nokia mobile phones.......
1helpful
3helpful
2answers
How to inser simcard in nokia 2680 slide
I can't get the aim card out! It won't slide or flip up or anything, I even put a knife under it and tried to jam it open. How can I get it out without damaging the phone?
I cant remove the back of my new phone to insert
i have nokia phone 2630 but i havelost my security code.is there any one to help me?
1helpful
Instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
