Epson LX-300+ II Matrix Printer Logo
Posted on Jan 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Custom page setup - Epson LX-300+ II Matrix Printer
Hans Pearson
Level 3:
  • Master 2,510 Answers
  • Posted on Jan 28, 2011
Hans Pearson
Master
Level 3:
Answers
2510
Questions
0
Helped
769909
Points
7758
Download the manual for your printer (if you do not have one) and select the setup you want from the DIP switch list, set the switches accordingly. The switches are at the back of the printer next to the parallel plug socket.
Why won't my printer print more than 1 Page at a time?
Please go to your printer preferences and select page setup choose default setting and customize other page setup then click apply and restart your PC. If not done then follow the instruction.
1. uninstall your present printer driver.
2. Restart your pc.
3. Install your printer driver again.
4. Restart your pc.
Hope it will solve it.
Thanks
Set page margins when Page SetUp does not work?
You should set up margins selecting and pressing with cursor at CUSTOM MARGINS, It should work.
Can not find WPA number to connect with internet a PS3
This is a cut and paste but it saves me time typing.
Find the Netgear router's WPA code on its setup page. Access the setup page by typing "192.168.0.1" into your Web browser's address bar and pressing "Enter." If that number doesn't work, try "192.168.1.1" instead. Type "admin" as the username and provide your router's password. Use "password" if you haven't set a custom password. Click "Wireless Settings" at the left side of the setup page and read the WPA code from the passphrase box on the page.
I can't set access a custom paper size for my Canon MF4100 series printer. I've added a custom size through Printers and Faxes > Server Properties and set the dimensions. It is unavailable to...
  1. Open the printer driver setup window.
  2. Select the paper size. Select Custom... for Page Size on the Page Setup tab. ...
  3. Set the custom paper size. Specify Units, and enter the Width and Height of the paper to be used. ....set discord custom in private
  4. Complete the setup.
How i can set the paper size to maximum?
in print dialogue box there is option page setup
in page setup you may choose predefined sizes or CUSTOM size which you can define yourself
you must vote for solution
1helpful
How to print a custom size paper on HP Laserjet 2550 I used to be able to print pretty much any size of the paper with this printer, but now, I can not even find the ''Custom'' for the paper size in the...
USe the Page Setup in the word processor. It is how the word processor uses the printer that matters. There you will find Custom and you can specify the page size.
About using custom size page setup. 7" x 10". It takes it as B5 setting.
Your printer paper tray paper size is not set properly. Check the paper tray side guide and make sure it is adjusted properly to size of the paper you are trying to print. If this is a printer go to print property or printing preference and select the paper size. I hope this will help you solve the problem.
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Custom size paper on xp
When you are in the page go to file, then print setup then go to advanced and it will let you do manuel adjustments or custom paper sizes. Depending on your printer you can also go to page setup and it will also give you page options..Be mucho blessed...Mark
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
