Have hooked sony dvd player with hdmi and can't get sound without have rca cable red yellow , same as with ps3 got picture with hdmi cable but no sound
I do not own a blue ray player but my son has a PS3. The thick cable is most likely HDMI and it should work without the red/white sound cable...try unplugging them so the auto detect feature if available and activated is not trying to compete by finding 2 sources. If that works great! If not, you can get a yellow RCA for the video and just use those as a source - again, don't use the HDMI cable and try it. If you don't have a yellow RCA, I've used another red or white for video testing to see if I can get a video feed. Most newer red/white cable will pass a video signal just fine and are only color coded for ease of hookup.
Rick:
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
It really all depends on what else you may have hooked up and, what inputs you have on your TV. If you have an open HDMI in on your TV, I would use that because you will get your sound and vidoe with one cable(HDMI). If you don not have an open HDMI port on your TV, component cables are the your next best option video wise. The component cables do not carry sound so, you would have to get your sound by using,(best) digital optical or RCA. After looking at your player, your best picture would be using component and, it says it has SPIDF out but doesn't exactly specify what kind but, if you don't have the component cables, use youe RCA jacks(yellow), video out, and red and white(left and right audio) out from player to suitable input on TV. If I looked at the right player, there is no HDMI out on it.
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
I would suggest this (you haven't said what kind of tv you have). I have a 37 in vizio, and a 25 vizio flatscreen HD tv. I had my PS3 hooked up using HDMI first time I tried it I got the little pixels you were talking about...so do this. Sounds stupid but it helped me. The HDMI cable where it plugs into the tv plug and unplug a couple times (three times worked for me. Do the same at the PS3 side of the cable. You want to do this with both of the machines off. Also make sure you have the PS3 configured appropriately for your TV settings...There is a way you can auto setup the screen and sound by shutting the PS3 off and holding your finger on the power button for like 5-10 seconds (it will beep twice) then let your finger off the power button.
When my HDMI cable went bad it would go from having a picture and sound to having no sound and a picture, to no sound and no picture. I thought I had a bad HDMI slot...but it was just a bad HDMI cable
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
