GE Profile Spacemaker Over-the-Range Microwave Logo
Posted on Feb 20, 2018
I have a stainless steel ge profile spacemaker 2.0. the screen appears dead until you open the door and then you see the set clock screen with numeric keypad. The touchscreen is not responsive to any buttons being pressed. I have tried turning the breaker off and back on but same thing.
5 Related Answers
Anonymous
  • 338 Answers
  • Posted on Dec 12, 2008
SOURCE: Need replacement glass turntable
looking about $65 from jacobyparts.com and and sears parts
Anonymous
  • 581 Answers
  • Posted on Dec 06, 2009
SOURCE: HELLO, On my built in over the range ge profile
http://www.geappliances.ca/jsp/ge_Listing.jsp?product_id=13&cmb_378=---&cmb_Colours=---&cmb_421=---&cmb_Brands=3&cmb_379=---
click on the link above and it will be able to supply you with your manual. It also has contact information so you can call toll free to ask your question.
1800-626-2000
Anonymous
  • 520 Answers
  • Posted on Mar 06, 2010
SOURCE: ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 22, 2010
SOURCE: GE spacemaker HVM1540DNWW. After I cleaned
Take a hair dryer in low / no heat setting or a plain old fan and let it blow on the keypad for a while. Do not let the key pad get overly warm. You got a bit of moisture in the pad membrane and the goal here is to evaporate the moisture. It may take longer than you think to evaporate the moisture. If you let the moisture stay in the membrane too long it will cause corrosion and the key pad will NOT be usable.
Anonymous
  • 8909 Answers
  • Posted on Jan 24, 2011
SOURCE: My GE Spacemaker JVM11490WD Microwave oven looses
I would check the house wiring to the appliance. There sounds like maybe a bad connection.
My ge spacemaker xl1800 light and fan turn on when door is opened. small piece of foil does not spark during this. is there an easy fix?
Kent, most microwaves will turn on the light when you open the door. As for the fan coming on, does it do that all of the time or only after you have used it for a period of time? If it does only after you have used it, you might want to check the back and the underneath of your microwave to see where the fan draws air into the unit and clean any lint built up on the vent holes. Hope this helps!
Direct replacement for pvm2070 microwave
The control panel assemblies for these touch screen models can now be repaired affordably if you have issues with seeing or setting the clock and operating it, etc. See details here.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWaveâ„¢ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
2helpful
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
1helpful
How do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
