Question about Kenmore 12502 Top Load Washer
The tub fills with water but does not start. I can hear the lid switch clicking when I close the lid
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jan 27, 2011
6ya staff
SOURCE:
Doesn't start after filling with water - model 110.15962401
check the lid switch,your lid switch is under the top console,open the lid and close it a few times you should hear a clicking sound,open the lid and stick your hands in the back above the tub,there's two clips one on each side that holds the top console down,or you can use a putty knife and stick it under the console and pop the clips,you'll see the lid switch on the left side,part number 8318084 and it's around 20 dollars.
May 09, 2011 | Kitchen Ranges
Whirlpool model # LLR6144BQ1 water fills but will not go to wash cycle.
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed lid switch that is item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996
First off put the washer in the spin cycle. With the lid closed see if the washer will spin. No spin also = bad lid switch. If the washer spins but will not agitate then the problem is most likely the water level pressure switch or associated air tubing. (any air leaks and it will not stop filling)
Water level switch is item 12 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996&diagram_id=28209075#d28209075
We test these with NO WATER in the machine and after connecting an external hose with the lid closed with power on by orally passing air into the small air hose we connected. It will click and the washer must agitate. If it clicks and does not agitate... again it points to the lid switch. Disconnecting this water level switch hose with ater in the maching and then re-connecting the hose WILL result in the machine overflowing. Tub MUST be empty.
You check the lid switch as you just open or close the lid. You should hear an audible CLICK as the lid is barely off of its closed position and again as the lid is almost closed. NO CLICK = bad door switch.
These are the 2 most common reasons that will correct the symptom your experiencing more than 90 percent of the time. There is a remote possibility that there is a problem with the motor / motor clutch. Motor clutch problems are noted by odd noises when motor is running and it will not spin or agitate. If the motor will spin the machine but will not agitate the machine it can be a motor winding.
Thanks for choosing FixYa,
Kelly
Mar 13, 2011 | Whirlpool Washing Machines
The machine fills and will not start agitating unless the lid is open and closed several times.
The most likely failure is the water level pressure switch or a failed lid switch. If the washer will drain and spin then it's not a failed lid switch. If it will not drain and spin the likely failure is the lid switch.
The water level switch (pressure switch) has 3 wires attached to it, V (violet), P (Pink) and a T (tan) wire. When the tub is empty of water, contact V&P are closed to allow the tub to fill with water. Once the water level reaches the desired setting, contact V&P opens and then contact V&T closes to start the motor agitating. So, with this said if you were to unplug the washer and remove the wires from the water level pressure switch and test to see if terminals V&T is closing by using an ohm meter would indicate if the contact is closed or not.
Jan 12, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Cycle won't start
the lid is not making proper contact with the lid switch, easy repair.
the lid is held to the maintop with a set of hinges. The left side hinge actually doubles as the lid switch actuator. so youll need to lift the lid, and feel for the opposite end of the hinge assy. when you feel the metal "arm " for lack of better word. youll need to bend it slightly towards the back of machine( usually use a hollow shafted screwdriver) as you bend backward the lid will want to close, so apply a little pressure. Your bending the "arm" to make better contact with the switch which ismounted tothe underside of the main top assembly. Before starting open and close the lid a few times and listen for the "click" of the switch activating. then recheck after bending youll hear a big diff
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer
the switch can be bypassed BUT if you do be careful it is after all a safety device to prtect those who "know no better than stick their hand in a wash tub spinning over 700 rpm" the switch may be on the left side just behind left lid hinge on some it was even under right side and others on right edge of lid opening either the screw holes are broke off or lever is not pressing in to activate switch..1 other thing ck screws in hinges if left side is loose have seen it fail to engage switch lever
Aug 07, 2008 | Washing Machines
Washer is full but won't start cycle
This is a symptom of a defective lid switch. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. Please post back with your number if you need assistance in determing part numbers. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very simple repair that doesn't cost a lot. If you require additional assistance, please let me know. I hope this helps you.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Apr 28, 2008 | Maytag Performa PAV2200
It fills up with but completely stops after it
If your washer fills, agitates, but won't spin out to rinse, this is usually a symptom of a bad lid switch. The switch is usually located on the right hand side of the washer tub opening around the rim where the lid seats. There is also a plastic plunger on the lid that will push down on the switch when closed to make contact. On some models, the lid switch is located on the left hand side of the lid in the rear. It is controlled by an armature on the hinge of the lid closing the switch contacts. Check the switch by opening and closing the lid. If you do not hear a distinctive "clicking" sound of the lid switch, the switch isn't working and/or the plunger may be broken off. If you can provide your exact model number (located under the lid of the washer along the rear rim of the tub opening) I can tell you which type of switch you have and the part number. Let me know if this is helpful. This is a very common problem with this model washer and a simple fix.
Sep 09, 2007 | Kenmore 24632 Top Load Washer
Whirlpool Washing machine top load
it sounds like ti could be the lid switch. Some whirlpool models will fill with the lid open. even before cheking the switch for continuity open and close the lid and listen for the "click". Ifyou hear the click then check the switch for continuity.
Aug 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 12502 Top Load Washer Logo
80 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
