I believe this code is ignition failure.
Turn power off and after 20 seconds turn power on with thermostat calling for heat.
Vent blower should come on first. After a bit igniter should lite up. You should hear click noise
of gas valve open up. If igniter does lite and you hear click noise, flame should come on for a few seconds minimum. If igniter doesn't lite and you hear click noise from gas valve, igniter is bad. If flame lites and then goes out, flame sensor probably needs cleaned.
Both igniter and flame sensor are in metal plate under burners. Igniter has 2 wire going to it and flame sensor has one wire. If you think it is flame sensor you can remove with taking it out with 1 1/4" hex screw. Flame sensor will have white film on it if it needs cleaned, clean with steel wool or a dollar bill.
If it isn't weither of these it is gas valve or circuit board.
