Question about Frigidaire Microwave Ovens
I have a Frigidaire FMV156DBC microwave. Just stopped "microwaving" half way thru - light stayed on and counter still counted down. After fooling around with it - I realized that if I pushed up on the bottom of the door -- it would run. What do I need to replace?
    Brigadier General:
  • 8,909 Answers
Replace after checking the door switches. If the interlock switches are not activating properly, things won't work.
Posted on Jan 27, 2011
6ya staff
SOURCE:
My Frigidaire PLMBZ209GCA Microwave stopped working. I was in the middle of cooking something for 10 minutes and it stopped working half way thru, but the display kept on counting down. If I try to use it...
If it stopped working while you were cooking my first guess is that the magnetron TCO got hot and opened. It is supposed to reset after cooling down, but if it is old it may not have done so. Of course, there should be at least two door switches that close when you close the door. There is also a monitor switch that closes when opening the door (open with door closed). If you remove the control you should be able to check continuity on all switches, but you need to remove the wires to get a true reading. Some M/O have a TCO on top of the cavity, but you need to remove the cover to get to that. If you need more help, just get back to me.
Aug 10, 2011 | Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Frigidaire microwave doesn't work
Don't have a fix for your problem, but my Frigidaire microhood just did the exact same thing--about the same age, started cooking some food and it worked for a few minutes and then just stopped--time kept going, light stayed on, but turn table stopped and fan noise cut out. I tried it a few more times and it seemed to fade in and out and then stopped trying.
Nov 30, 2009 | Microwave Ovens
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
How can u tell which switch is bad on the frigidare microwave
the door switches almost never break it sounds more like no power check the fuses on the pc bords
May 15, 2009 | Frigidaire FMV156DC Microwave Oven
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
Microwave Ovens Logo
556 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
