SOURCE: LG 18000 ac leaks water in the front of unit.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
SOURCE: unit is leaking water
What is causing this is when you have something cold, the moisture in the air condenses to becomes water. Kinda like when you sweat in the sun. They call this condensation. The unit should be collecting this and draining the water through a hose, or out the back. If there is a hose inside the unit, check that the hose is able to completely flow downwards at least 1/4" per foot. Otherwise, if the unit is a box in a hole or window, slant the unit so the water flows towards the rear.
SOURCE: Carrier Infinity AC indoor unit
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
