Cameras Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and cannot take anymore picture cos of internal memory full. pls help thanks. i did read the book instruction but nothing for troubleshooting there.
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Jan 27, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
219129
Points
3782
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
MY CAMERA IS A Z650 KODAK EASYSHARE, MY DAUGHTER LOST MY OLD MEMORY CARD SO I WENT OUT AND BOUGHT A NEW MEMORY CARD BUT MY CAMERA SAYS IT NEEDS FORMATTING AND IT WONT LET ME ALSO IT SAYS INTERNAL MEMORY IS...
Just as I suggested. The Z650 works with SD cards, not SDHC cards. Most likely your old card was 2GB or smaller and your new card is 4GB or larger. Try using a 2GB SD card.
You can clear internal memory by deleting the pictures it contains. Download them to your computer first if you want to preserve them. You can get rid of all of them in one shot by using the "Format" command in the Setup menu.
I can only take pictures on internal memory despite trying two different memory cards, and making sure they were unlocked. So, how do I get it off "internal memory only" ? Gary
Gary, I'm guessing that you just bought a new 4GB SDHC card. You do understand that your camera model can only use 2GB or less standard SD card (still available on Amazon)? Please see this link.
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
If the camera says the internal memory is full and won't allow me to take any more pictures, do I need to get a new card reader?
Your camera has only 32MB of internal memory, out of which only 13.5MB only is used for picture storage, which allows you to save only a few pictures. If you need to shoot more pictures you need to buy SD or SDHC cards or micro SD cards. If you buy micro SD card, then you also need to buy an SD adapter. SD adapte is very cheap, usually less than a dollar. The maximum size SD card you can use in Kodak Z915 is 32GB SDHC card. SD card sizes are available only upto 2GB. SDHC cards goes from 4GB to 32GB. Again these cards are rated based on their speed classes. It is preferable to buy Speed class 6 and above for good video recording. With higher speed class, speed increases. If you want to shoot pictures faster then you need higher speed class memory. Price of the card increases with the speed class. You can buy speed class 2, 4, 6, 8 or 10.
If you want to download your camera manual, try the following site:
http://resources.kodak.com/support/pdf/en/manuals/urg00995/Z915_xUG_GLB_en.pdf
1helpful
Just bought camera kodak easyshare C195. Took 6 pictures now it says internal memory is full. How do I fix this without having to pay for information. I paid enough for the camera to not have problems
Your camera has only 32MB of internal memory, out of which only 19 MB is available for picture storage. So you can store only a few pictures.
The actual number of images and videos will vary depending on the length, reolution and compression used. For an example, a 1GB memory (1000MB) can store approximately 200 photos at 12MP resolution at 4.6MB file .
You need to buy an SDHC memory card ( micro SDHC card is also fine, then you need an SD card adapter) to store more pictures. These cards are available from 4GB to 32GB , and at different speed class ratings. I would recommend minimum class 4 speed rating so that you can capture high definition video.
These SD memory cards are available at standard stores. One place you can buy them cheap is through ebay. You buy through auction. New ones or used ones. Usually, you may be able to get at half price.
1helpful
INTERNAL MEMORY IS FULL EVEN A NEW SD CARD
Go into the camera's menu and transfer the contents from the internal memory to the SD card. the camera has a card inside it with limited memory which is seperate from the SD card.
Regards.
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 1helpful
    Unreconized file format and also says interal memory full
    Internal memory is full as you have been saving pictures there rather than your card. Have you checked those are not your missing photos?
    Get a new sd card for your camera-I keep 3 cards for mine so that I don't need to delete anything for ages. I back up all photos to pc. The photos on your internal memory can be copied onto your new sd card when you insert it. When you are certain they are on the card AND backed up on the pc then you can delete them from the internal memory.Try mrnu>image storage. On your internal memory there will be an option to copy the photos to a card when you have one in your camera. Do check the internal memory-it is full of pictures-they may be the ones you want!
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
