Hi.
Try disconnecting power cord for ten minutes (turning off is not enough). See if that does reset the fridge.
If that does not help, then check if there is ice forming in evaporator coil at the back of the fridge. Eventually wait one or two extra day. If ice starts forming and fridge quits cooling, then you have a problem with the defrost system. Likely the thermostat or the defrost timer.
IF the unit keeps cooling regularly, and defrost is OK, then it may be a disconnected temperature sensor. This will cause beeping, and fridge cooling regularly.
About defrost control, see this article: When the fridge is not cooling ...
To find parts and diagrams enter the model number in the links listed below, try all the links listed:
Where do I find parts and diagrams?
If you need to contact a technician use the Fixya directory (US only).
Regards.
Ginko.
