Onix mp3 player operation manual
Try this:
http://www.tempoaustralia.com.au/mp4/p13/MP4%20instruction%20manual.pdf
I hope this manual belongs to your player:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Bye, gylacz
SOURCE: I have no idea how to charge the battery
If it has no obvious battery connections, then hook it up on your USB cable and see if you computer will do it. Mine does.
SOURCE: virus problem with brand new onix mp3 player
Lifted directly from the manual:
http://www.tempoaustralia.com.au/mp3/im/ONIX_MP3_Player_instruction_manual.pdf
Some users have been experiencing their antivirus programs on their computer incorrectly system files on the mp3 as Trojan files. Please follow the procedure below to correct this issue:
Step 1. Turn unit on and select "System" menu. Press "M" button to enter menu.
Step 2. Press "right" arrow 4 times until "Audio Auto Transfer" is highlighted
and press "M" button to enter menu.
Step 3. Press "right" arrow to highlight "close" and then press "M" button to
select.
Step 4. Press "Play/Pause" button to exit system menu.
After the above procedure is correctly followed, the MP3 will no longer be incorrectly detected when it is connected to a computer.
SOURCE: I need a full instruction manual for an ONIX MP3
you can download it from the tempoaustralia website
SOURCE: MP3 Player, ONIX from Aldi,
The MP3 player is charged using the supplied USB cable. connect the player to this cable and plug it into a computer's USB port when the computer is running.
SOURCE: Need instruction manual for Onix
Hi, Player wont charge, plays when connected to computer. Can you unscare battery may have not charged it continusly for 12 hrs.
