Wow, so many solutions, which one do you choose.. Press and hold the power button until
the systems shuts off. (wait 2 seconds)
Press and hold the power button again
until you here 3 beeps. Let go. You should see, in either HDMI or AV, a screen that ask you to 'connect controller and press ps button.' If you see this menu with AV and not HDMI, then you will have to use AV. If you do not see this in either TV input, then this is what you have:
Ok, here is your answer:
Yes, plug in both HDMI and AV cables.
Then you have what is commonly known as the
"Green light of Death."
It is when your system powers on and acts normally but no display.
Your GPU (graphics chip) has cracked or become damaged and will need
to be sent in to SONY. You can try a 3rd party technician, but this
repair has a very very low success rate.
Thanks for the quick response Mike. I'll try that. By the way, last night I was able to see the screen while in "video 2" which is the Component AV connction. But I was not able to see it on "Video 7" which is my HDMI input. Does that mean my internal card for the HDMI port is fried?
Yes, and it cannot be repaired by a 3rd party technician. But hey, I guess there is always someone better than you (I mean me). Have a good day.
Considering that you would have to send it to SONY, you will have to contact them directly for the correct pricing information: 1800 345 SONY.
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="line drawing of HDMI connection">
alt="line drawing of AC power cord">
How much do you think it will cost me?
