Try the Electrolux support site >>>>> Support
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, you can replace the 4 original EMX1600sS batteries . The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work.
Ok, I purchased the batteries you recommended. What is the best way to attach them together? Solder?
