Our Samsung RF265AB (bottom freezer) is leaking water under the cool select pantry door and the air vent behind it is freezing up. we defrosted the ice and wiped up the water but it water keeps blowing out of the vent.
This is caused by a blocked defrost drain. The cold air for the fridge is vented from the evaporator behind the freezer. Once every 24 hours the defrost timer, stops the compressor and applies power to a heater at the freezer evaporator coils. The defrosted water drips and runs to a drain normally into a metal tray on the compressor where it evaporates. On my GE fridge freezer there is a hose and a small p-trap at the rear. Easy to remove, soak in bleach and hot water and then flush through. Help for Samsung drains in the link.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Hi Mike, You could have an outside airleak which would let in warm moist air into the freezer.OR the condensate drain tube is plugged up or frozen up. thats the drain tube that drains the melted ice from the freezer OR the condenser fan located buy the compressor is not running. Check all drain tubes and drain channels for clo- ging or freeze-up due to improper and complete draining.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment. The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water. The exact location of drain is under the coil behind back freezer plate in the center
Defrost that drain with a hair dryer and remove the debris . That should solve the problem . The red you see ( this is normal ) , is the defrost heater , thawing out the frost on the coils . The defrost water HAS to go out the drain or it will freeze the opening and the defrost water will flow out thru the bottom of the freezer door .
