Question about Bose Wave Radio
How do i setup my radio as an alarm instead of hearing the beeping for my Bose radio??
    Brigadier General:
  • 8,546 Answers
6ya staff
SOURCE:
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Jul 22, 2014 | Bose Wave Radio
Wave radio comes on randomly
Random is truly a difficult problem to solve, if no pattern of failure can be detected. It sounds as though the alarm may be at fault. Is the alarm on and set to radio, CD, or beep? If radio, that could pinpoint the problem. If you have another, mechanical alarm, use it for a couple nights with the Bose Wave alarm off. If the Bose still acts up, then it isn't the alarm. Try unplugging the unit, waiting at least 30 seconds, and plugging it back in, which will cause you to need to reset the alarm. Alternately, remove the Bose cover and blow out dust. I find the Bose susceptible to dust as a cause of malfunction, which may point to the cause being the compact design of the unit. Good luck.
Jul 09, 2013 | Bose Wave Music System CD Shelf System
Clock in 24 hour mode how do I change to 12 hour time mode
On first generation Bose, press "Alarm Setup" and "on/off" button to toggle between military and 12 our time.
Older model documentation:
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf
Dec 04, 2010 | Bose Wave Radio
How do I convert from military time to standard time?
Changing the clock time format You can choose to have the display show the time in 12-hour (AM/PM) or 24-hour (Military) time. 1. Alarm Time Menu Alarm Time Menu Tune Press and hold Alarm Time (Menu) until -SETUP MENU- is displayed. 2. Press Tune > three times until TIME- is displayed. 3. Press Time - or Time + to select 12 HOUR or 24 HOUR. 4. Press Alarm Time (Menu) to exit the setup menu or wait 10 seconds for the setup menu to end automatically.
I also have the pdf formatted Users manual http://products.bose.com/pdf/customer_service/owners/og_wrii.pdf
Oct 12, 2010 | Bose Wave Radio II
Reads 24 hr instead of am and pm
Push and hold alarm time button to bring up “SETUP MENU”. Push the right tune ">"button 3 times and that should bring up the 12/24 hour display. Push the time + button to set back to 12 hour time.
Mar 05, 2009 | Bose Wave Radio
I have a bose wave model awrc-1g cant set time from military time to regular
Hold the alarm setup button and at the same time hit the on/off button.
Oct 16, 2008 | Bose Wave Radio
Setting time
May 29, 2008 | Bose Wave Radio
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
instead.
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
How do I make my alarm on my Bose Wave Radio play the FM Radio instead of the usual beeping noise?
When you choose the alarm button on the back row of buttons in the middle you get 4 options, no alarm, beeping, music, beeping & music. These are represented by icons on your front panel the note and the ))) sign.
Regards
Derek
Dec 20, 2007 | Bose Wave Radio
Bose Wave Radio Logo
159 people viewed this question
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
