Sony PlayStation 2 (PS2) Console Logo
A
Anonymous Posted on Jan 26, 2011
I cant unlock my ps2 console to watch a region 1 dvd and ive tried some unlocks but they wont work
Jesse Allen
Level 3:
Master:
  • Sony Master 307 Answers
  • Posted on Nov 12, 2018
Jesse Allen
Sony Master
Level 3:
Master:
Answers
307
Questions
0
Helped
160973
Points
1872
The best solution to the region code issue would be to create a region free copy of your DVD discs. You can play a region free DVD on any DVD player you like. Try Leawo Blu-ray Copy. It's one of the best Blu-ray/DVD copying program. You can use this program to create region free copies of your Blu-ray/DVD discs to play on your PS2. The post that follows will show you how to use it to create region free copies of a Blu-ray/DVD disc: How to Make 1 1 Disc to Disc Blu ray Backup with 1 Click Blu ray Copy...
Eddie Chen
Level 3:
  • Master 661 Answers
  • Posted on Jan 26, 2011
Eddie Chen
Master
Level 3:
Answers
661
Questions
5
Helped
116734
Points
1805
Make sure your console has the ability to read region 1 discs in the first place.
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
If you forgot the parental control code and you need to unlock that, though, then try this:
1.Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under
custom setup.
2.When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3.The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4.Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
  • 1 more comment
  • scorpion013 Mar 10, 2011
    the code worked on my ps2 it saved the settings but it still didnt play the dvd the dvd has a code rating of canada and its 18a rated so why wont it play it
  • Eddie Chen Mar 11, 2011
    I am not familiar with that rating, so i would not know. sorry i can't help you any further.
    w8, where did you get the console?
2answers
The problem i have is simple but complicated at the same time my ps2 wont play the region 1 dvd witch has a rating of 18a and its a canada one ive changed the settings but it still wont play it its just...
Hi scorpion013,
PS2 games are region locked which means that disks from other regions won't work on your PS2. If it keeps displaying that message it means that you need to buy the region appropiate disk.
Sorry about the inconvinience.
-Luchen
3answers
Playstation 2 region unlock
Hello there.
To region unlock your Playstation 2 console you need an unlock DVD. Something like http://www.play.com/Games/PlayStation2/4-/94716/-/Product.html
Hope this helps.
tip
Playstation2 Region Free Fix
Sony Playstation 2 DVD Player Region Free Fix
Would you like to unlock your Sony Playstation 2 DVD Player to Region Free?
There is more than one model of PS2, and more than one PS2 DVD player module. For some models or modules, only a Messiah 2 or Magic 2 chip installation will make them region free. However, many can be made region free, for free.
Follow these steps to unlock your Sony Playstation 2 DVD Player:
  1. Press and hold CIRCLE, RIGHT, L1
  2. Press and hold L3 and push the stick in hard
  3. Boot into the PS2 browser without a CD/DVD in the tray
  4. Press CIRCLE and R1 on the DVD
  5. Hold RIGHT until a menu appears
  6. Press CIRCLE and R1 again
OR
  1. Load the DVD into the PS2
  2. At the browser screen, select the CD icon the press and hold SQUARE then CIRCLE until the DVD menu appears, holding both buttons all of the time
  3. Either select the PLAY icon or the MOVIE START icon
Your Sony Playstation 2 DVD Player is now Region Free.
I hope that helps.
Region unlock PS2
Try this Tip for the steps:
I hope that helps.
1helpful
PS2 Unlock region codes
YOU CANT the ps2 is REGION LOCKED so you can only watch the dvds on the ps2 that match the region code, there is NO software to unlock this and there is NO way to make them work.
Unlocking UK PS2 region code to play an Australian dvd
Yes, you have to get a disc that makes it compatible with that country, search up PS2 country configuration discs.
Multi Region Unlock code
I hope that helps.
Region 1 dvd and blu-ray
Hi Phil ,
You need to "unlock" PS3 to play the region 1 DVDs.
http://youtube.com/watch?v=yzlL7Ac0LZI&feature=related
http://forums.gameaxis.com/showthread.php?p=21259246\
http://www.youtube.com/watch?v=QSG2ufwA6Xk
http://www.dcemu.co.uk/vbulletin/archive/index.php/t-48566.html
Please click all the above links
GoodLuck :)
1helpful
2answers
Over ride the parental control level
Ok first try 0 1 2 3 because that is the preset code for the ps2 or if that dont work insert any dvd movie, go to setup and access the parental control settings(press select) When asked for your code enter "7444"; It will prompt you again to type in your password. Type "0000" and then scroll down to the movie rating options and choose "off". Hope it helps you out!
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
