SOURCE: wet iPod
i have heard (not sure if its true) but for phones if they get wet you put it in a sock and then in a dryer it will work, maybe it will work for a ipod but i have no idea if it works. Thats just a suggestion.
SOURCE: Ipod nano and ipod video 5th generation
First off, simply press the center and menu buttons at the same time to reset the iPod video. That is the common way to fix a frozen iPod.
In regards to the Nano, sounds like the scroll wheel is defective. We would recommend replacing the scroll wheel if a reset does not do the trick.
Rick
EverGreen Electronics
SOURCE: apple ipod nano second generation
ok, i can help it happened to me too all you have to do is hold down the middle button and the top button(play)at the same time
SOURCE: Ipod Nano 3rd Generation volume problems
ITunes contains a volume leveling program that works with every recording in your library or you can select each one individually by going to the library, selecting get info with the right mouse button, select options, and change the volume with the control you see on the screen and press ok.
SOURCE: ipod has froze
have you guys tried a reset?
To reset your iPod:
