Hi,thanks for using fixya, You can get the unlock code and instructions through online. only you should give your IMEI number and get the unlockcode for your mobile. You can also get the IMEI number by entering this on yourphone *#06# It will then display your IMEI number and you may alsoget a unique global serial number. Your IMEI number should be 15 digits. There are so many software can help unlock, you can download from bellow link, http://www.top4download.com/free-nokia-unlock/ or Step by step guide http://www.unlockme.co.uk/unlockme.html NokiaFREE unlock codes calculator for windows allow to useyour mobile phone with any service provider around the world. Repair, remove sim restrictions and unlock Nokia, Samsung,Siemens, Maxon, NEC, Sony, Panasonic, Vitel, AEG / Telital, Alcatel cellphones. How to use: You only need to enter IMEI, to get IMEI numeryou must press *#06# at your mobile phone keyboard and enter. To unlock nokiamobile phones you should select the operator company where you bought yourcellphone or where your cellphone is locked. DOWNLOAD LINK http://download.cnet.com/NokiaFree-Unlock-Codes-Calculator/3000-10440_4-10318195.html OR http://www.topshareware.com/download.aspx?id=42084&p=&url=http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip 1.Install >2.start>3.prograame 4.>Nokia freecalculater>5.l click >6.insert your office xp in cd tray(If the frontpage not installed) 7.Seclect company 8.model 9. type IMEI,no 10.Country 11.Name sim provider(Huchition) 12 Go step by step !3 .AFTER SELECT ALL JUST CLICK ON CALCULATE You can see you unlock no right side and copy for yourmobile . IF YOU THINK IT IS CRITICAL TAKR HELP BY ANTHER You can take the help through bellow link. http://unlock-zone.com/ Or you can follow the fixya suports tips bellow link http://www.fixya.com/support/r2831734-phone_lock_code_lost_no_problem_get website for unlockingyour mobile .There are so many website for unlock mobile, but it is recomendedby mobile forums.This side is really perfect.Only you need to wait fewminutes.. Hope this helps. If you are helped you can rate on the 4 thumbs and leave ashort comment,because, this is the free sideand I can get the chance, to help people like you . Thanks for using fixya .
The code for the phone lock of motorola is 12345
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
