You must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
