SOURCE: 28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
SOURCE: can I put to wash the comforter in speed queen washer swt912wn?
2.8 cu. ft capacity
you can wash a king sized comfortor in it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
