My 50 inch plasma magnavox flashes a red light 4 times ( code) after you turn it off. Will not turn on unless you unplug it for 10 seconds or so.Then you can watch it with no problems. Do you know what is causing this. Thanks
You have bad 2200uf 16volt capacitors in your power supply, probably 4 of them. I repaired a unit with this exact problem a bout 4 weeks ago. If you have a friend or family member who knows how to solder, you can get the parts for under $10.
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
get a memory stick( flash drive) and up load their soft ware from their
site. I plug the stick into the computor and uploaded the software.
I then plugged the stick into my TV on the side. A screen came up and
the software loaded on the TV successfully. The red light then turned
to green. However, I now have to unplug and plug the TV several times
for it to turn on. It works fine but once the TV is turns on, but when
I turn it off and it cools for a while I have to repeat the same
proceedure off plugging and unplugging
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video
devices, Blu-ray Disc Player, DVD Recorder, etc. The front or side HDMI
inputs only are designated for PC. To use the TV as a PC monitor, advise
customers to use only front or side HDMI inputs.
