Question about Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
If you open the panel where you replace the ink cartridges there is a square hole directly behind the control panel. The area gives you enough space to put your hand under the plastic and you will feel what I only describe as a plastic latch, pull it and you should feel the control panel loosen to then be able to close.
Hope this helps...
Posted on Mar 06, 2011
The above comment is totally misleading .....
There is no latch,
and you should not pull, you need PUSH!!
and you do not open printer cover!!!
The right way is put you hand under printer control, right in the middle, you see/you fee there are 3 vertical line, push it hard with just one of your finger, you hear a sound, then you can fold it.
It is so disappointing Lexmark does not write it in user manual., waster me one evening.
- Ryan Liu
Thank you Ryan Liu!! You saved us a ton of time!
Thank you RyanLiu_99. I do it with your instruction and it works.
Actually, I tried both and they are both correct. The first answer is kind of doing it backwards, but it works. The second answer also works, but if you don't lift the panel first, you have to exert A LOT of force!! When it finally did give my finger got cut on the "latch" that alkesh2004 was talking about. (The "latch" is actually a plastic barrier that holds the panel up and what the panel slides past while closing.)
So, again. If you place your hand under the control panel, find the grooved "button" with your fingers, gently lift/tilt up the panel, THEN press very firmly, and you'll feel the plastic give under your finger's pressure. The panel will note close flat.
Hope it helps!
Posted on Oct 22, 2014
Dec 19, 2017 | Pro Office Equipment & Supplies
Sep 23, 2016 | Lexmark Prospect Pro205 Wireless...
Feb 06, 2015 | Lexmark Prospect Pro205 Wireless...
Sep 15, 2014 | Lexmark Prospect Pro205 Wireless...
Jun 30, 2014 | Lexmark Prospect Pro205 All-in-one Inkjet...
Apr 13, 2012 | Lexmark Prospect Pro205 Wireless...
Jan 30, 2012 | Lexmark Prospect Pro205 Wireless...
Aug 29, 2011 | Lexmark Prospect Pro205 Wireless...
Apr 17, 2011 | Lexmark Prospect Pro205 Wireless...
Nov 14, 2010 | Lexmark Prospect Pro205 Wireless...
3,543 people viewed this question
