Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: transferring pictures from my Kodak EasyShare digital camera to my computer
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
SOURCE: "The device is not ready"
SOURCE: Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
SOURCE: Kodak EasyShare C613 not able to connect through USB
IT TELLS ME CANT LOCATE MY DRIVER FOR MY KODAK C613 CAMERA
SOURCE: need to know how to transfer pics back to camera
From your computer "to" the camera? This seems backwards but you would pop the SD card out and put it in a card reader (your USB cable might work too) and copy the files using My Computer. the camera will appear in My Comuter as a drive letter.
