Hi Dave.
The problem you are having is the adaptor you tried is the right voltage but not the correct ampage. You require a 12v dc adapter with a rating of at least 1-Amp. The switchable supply you purchased would be well under the required level, probably 400ma (milli-amp), in other words about half the needed amount. A cable modem power adapter would be sufficiant. If you have one, make sure it is the correct voltage and polarity, positive pole (+) usually the inner pin on the end of the connector. Hope this is of some help to you.
Testimonial: "Really useful advice. Makes sense and easy to act upon advice given."
