Cameras Logo
Posted on Jan 25, 2011
Minolta lithium ion battery BC 200 charger has failed. Product reference 91-59041 Phihong DEC.
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jul 24, 2007
SOURCE: Camera won't charge
The camera manual will tell the battery type. If you do not have the manual then the makers web site customer support is the place to go. The same applies to the charger - if it does not supply enough current then the battery will never be fully charges.
hai nguyen
  • Posted on Jun 18, 2008
SOURCE: Battery charger light flash
Use the 9V as Ricckk suggested in Solution#2 and it works like a charm (make sure you hold the 9V against the casio battery for about 20secs with the the right polarize i.e. + with + and - with - ). As well as the phone number Dobetta gave in Solution #4. I now have a spare. Thanks Ricckk and Dobetta.
Anonymous
  • Posted on Oct 28, 2008
SOURCE: my casio lithium ion battery np 20 flashes when Im charging it...y?
Yes you need a new battery, call 1 800-706-2534 and ask for a new battery. If they say no, try again with somebody else until they send you one for free
Anonymous
  • 3 Answers
  • Posted on Apr 13, 2009
SOURCE: I lost my battery charger and i need to charge my camera battery
you now can buy chargers to replace lost ones, i work in a camera shop and sell a brand called Hanmel. they do a range of the most popular brands of camera chargers, just check the back of the hamnel packaging it to see if it it compatable with your battery
Anonymous
  • 8 Answers
  • Posted on Sep 30, 2009
SOURCE: I lost my charger for my Norcent DCS 860 camera i
Looks like you can get the charger here:
http://www.inter-batteries.com/norcent-dc520-dcs760-series-battery-charger-p-13492.html
1helpful
Battery charging
Depends on how much the battery is in use, and how much battery life is left.
If it's relatively new (3 years old) and fully empty, it could be full by 2 hours - 2 h 30 min. If it gets really hot before that time, it's full by then.
3helpful
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
2answers
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
What is BP-400?
BP-400 is a exclusive external power battery pack for DiMAGE A1 and A2. It can be attached to the body and has portability and movability. It is very convenient for the customers who want to use AA size battery or take a long time picture. One or two exclusive lithium-ion battery NP-400 can be attached. 6 AA batteries; Ni-MH and Alkaline battery can be used. (Nickel dry battery and lithium battery cannot be used. Recording: Approx. 560 frames,continuous playback: Approx. 480 min.(2 pcs. NP-400 batteries) Recording: Approx. 290 frames,continuous playback: Approx. 270 min.(6pcs. 2100mAh Ni-MH batteries) Recording: Approx. 80 frames, continuous playback: Approx. 80 min. (6pcs. Alkaline-manganese batteries) Standard Accessory: Holding Strap HS-2 Optional Accessories: Dedicated lithium-ion battery (NP-400), battery charger (BC-400) INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V 700mA
What is the external battery pack "EBP-100"?
This is the external battery pack used for the DiMAGE A1, 7, 7i,7Hi, 5, S414, S404, S304, Z1, Z2 and A2. This is the type of external battery pack that connects the camera and the battery part with a cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Two lithium batteries NP-100 Approx. 480 frames(recording), Approx.450 min(playback) Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Battery Charger BC100 is sold separately. INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
1helpful
What is external battery pack "EBP-100"?
This is the external battery pack for DiMAGE 7, 7i,7Hi, 5, S414, S404 and S304. This is the type of external battery pack to connect the camera and the battery part with cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Battery:Two lithium batteries NP-100 Battery performance: Approx. 580 frames(recording), Approx. 580 min(playback) Accessories: Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Optional: Battery Charger BC100 is sold separately. BC-100 specifications: INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
2answers
Top Minolta Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
