Canon Pixma iP2700 InkJet Photo Printer Logo
A
Anonymous Posted on Jan 25, 2011
How do i reset the canon ip2700? - Canon Pixma iP2700 InkJet Photo Printer
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2595
Points
17
This is the fastest inkjet printer nigeria has ever use. in most company in nigeria you will fine ip2700 USB color inkjet photo printer
4 Related Answers
Anonymous
  • 1705 Answers
  • Posted on Jul 19, 2011
SOURCE: how to reset canon ip2700
You need to update your driver for win7.
The nearest model to your that I can find is the IP2702 on the US website:-
http://usa.canon.com/cusa/support
If you prefer you could try the UK/Europe website, but I didn't see your model listed.
http://software.canon-europe.com/
You'll have to use the menus and enter your device, model and O/s details. There are 2 versions of Win7 32 bit and 64 bit. If you choose the wrong one it won't load.
Anonymous
  • 1044 Answers
  • Posted on Sep 20, 2011
SOURCE: how do i reset ink
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
samaddar07
Avishek Samaddar
  • 639 Answers
  • Posted on Mar 31, 2011
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Anonymous
  • 123 Answers
  • Posted on Dec 02, 2011
SOURCE: my Canon ip2700 wouldn't print. Aligned heads and changed cartridges.
what does it say when you try to print? brother ink cartridges
2helpful
How to reset my canon printer ip2700
I have a Canon IP2700 printer. My PC said it will not work with internet Explorer. What can I do?
How to reset canon iP2700
press stop button for over 30secs...
My canon ip2700 colour wont print
how to overcome my ip 2700 canon 006 error?
4helpful
Error no 5200 in ip2700 printer
This WEB site may be able to help you with this problem.
http://abufaiz-online2.blogspot.com/2010/12/reset-ip2770-canon-blink-13x-orange.html
3helpful
How to reset canon ip2700 for windows 7 ultimate
1helpful
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
old marine
old marine
ZJ Limited
ZJ Limited
