Card was inserted into digital phot frame slot the wrong direction. Now when the card is inserted into camera, camera freezes. Is there some way to reformat the card so it will work or is it toast?
How did u try to download pics? What i know is that there are two ways to save something from a memory card to a PC. One way is via USB cable and other way is directly from mem card. If you're trying to save your pics from CAM to PC using an USB cable and not working at all then try opening up the memory card from your CAM and insert the card directly into your laptop in the laptop's memory card slot but if there isnt any slot, try to get it into a card reader and then attach the card reader with your PC. Hope it will work for you, best of luck.... x
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
It sounds as if you have an SD card reader, not an SDHC card reader. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. SD devices are limited to cards 2GB and smaller. SDHC cards begin at 4GB and go up to 32GB.
becoz then the autoplay of the drive will be activated and it will freez your computer......recomandation is to format the drive in computer not in the cam, or you can open the SD drive frome 3rd party software (total commander), and delete the hidden autorun files.
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
