Try the DVD-disk in some other computer, to see if the disk is the problem in _more_ than one computer.
Try some other DVD-disk in your computer, to see if your Sony drive can read _any_ DVD disks, i.e., if _NO_ disks can be read, then it's time to replace the drive.
It seems that you're running a 32 bit version of the software on a 64 bit operating system. Or the driver is not longer supported by modern Operating systems. To fix this issue try finding and installing the right driver.
Open Device Manager, click the + sign next to DVD/CD-ROM drives. Right-click on the drive and choose Uninstall Driver. Shut down your system, and restart. When Windows starts it will detect the new hardware and install the software for it.
Also, try uninstalling your burning software, restart, and re-install. It may be that the software has got corrupt.
Hope they work, and let me know if they do or don't.
Your Sony CD-RW is an ATAPI CD-ROM for the purpose of your BIOS. Without you specifying the motherboard brand and model, it is hard to tell you what your issue could be.
Nearly all PC motherboards made after 1995 will allow you to boot from the CD. Enter the BIOS setup screen by pressing, during POST, <DEL> or <CTR>-S (Gateway), <F1> or <F2> and look for boot sequence. Some MB's have a boot sequence key you can press to select the boot device for that boot instance only.
If you are trying to say that you have an ATAPI CD-ROM and the Sony CD-RW, then check your master/slave/cable select jumper settings on the device. Each IDE channel can have at most one master and one slave.
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
I think your DVD burner is faulty and requires replacing, as they are very innexpensive to replace as you wili probably know,so don't waste too much time trying to solve it.
It isnt the decoder as thats a peice software
that comes in certain burning programmes,
the laser is able to read cds as the tracks are wider apart than dvd's and are easier to read.
The drives dont last as long as they used to because, keeping the price of burners down, like anything else means cutting corners and costs and in burners cases as was the case with PS2's the lasers are cheap and soon fail.
