SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
SOURCE: Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
To set the system Time:
1. Press
Speaker.
2. Dial
728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
