SOURCE: Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
SOURCE: aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
SOURCE: Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
SOURCE: i have aprilaire 700 humidifier, running nonstop
Hi check out the stat is working also check water line valve is not stuck open or there is some thing stuck on the seating
