Jet 3 Ultra Power Chair Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a jet 3 ultra and send to my country is chile, Chile's electricity is 220 volts, then went to buy a power transformer as used here in is 110 volt. at the store told me that if you have transformer from 110 to 220, 4 amp. but tell me how many watts is the electric chair. I can tell you how many "watts" I buy the transformer? grateful rob
Anonymous
Level 2:
Scholar:
  • Expert 41 Answers
  • Posted on Jan 24, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
41
Questions
0
Helped
66327
Points
109
Jet 3 is typically 50 amp.
The controller is 40 amp.
What do you mean transformer?
Are you trying to charge? Do you have an onboard charger or separate unit?
I owned a medical equipment company for 10 years, so I know a bit about these, please provide more specifics as to what you are needing.
Model el 174 4. Where can I get a replacement transformer?
you can buy at your local electronics/electrical store by the way what is the current in your country? if 220 volts just by a step down transformer to be able to work your 110 v fan...if 110 volts already why you need to put transformer if only plug and play...
Sep 21, 2015 • Dryers
Solis 365 royal hair vac I was wondering if it was possible to use this product in australia due to the voltage difference and if there is a product made to suit australian voltage or if an adaptor...
There are products called Step Up transformers/Step Down (Voltage Converters) that can be used. We use these For our 220VAC Australian manufactured lasers when we need to run them in a Dr.'s office that only has US 110VAC.
Info from a website:
Electrical voltage in USA is 110 voltwhereas; the voltage in most of the foreign countries is 220V to 240 volt. A voltage converter / transformer, also known as power converter are usedto convert electricity coming out of the wall to match the voltage of yourdevice. These Voltage transformers or converters can be used safely withRefrigerators, Microwaves, Juicers, Blenders, Coffee makers, Power Tools,Stereo Systems, TV's, Video Games, DVDs, Hair dryers, Chargers, computersand other electronics when travelling abroad..
Remember to leave at least a 100-percent margin for power surges/spikewhen buying a transformer. Some items, such as Televisions, computermonitors spike when you turn them on. For these products you need to buy avoltage converter transformer that is at least 3 times the items capacity.Power tools, laser printers and heating appliances like coffee makers,toasters, microwaves, Halogen, Fluorescent bulbs you must leave a marginof 3-4 times.
Voltage transformers are made to convert single phase 110 or 220 volt.American 220 Volt consists of 2 phase of 110 Volt and European 220 Voltconsists of 1 phase of 220 volt.
Volts x Amps = Watts (i.e. 110V x 0.5 AMPS = 55W). Please make sure not torun any appliance with higher wattage then voltage transformer's wattage.This might damage both: your appliance and the transformer!
I hope this helps.
PHmaddnes Transformer Purchase Guide
May 06, 2014 • Cell Phones
I have a crosley CR8005A and i conected in my country (CHILE, SOUTH AMERICA) and here we have 220 v. can it fix it?
You need a step-down voltage converter to convert 220V to 120V.
Amazon has them. One example - http://www.amazon.com/VCT-VT-300-Voltage-Transformer-Converts/dp/B000J65PJQ/ref=sr_1_13?s=electronics&ie=UTF8&qid=1365005058&sr=1-13&keywords=convert+120V+to+220 or http://www.amazon.com/Voltage-Converter-220-240-110/dp/B001ES8YY6/ref=sr_1_2?s=electronics&ie=UTF8&qid=1365005058&sr=1-2&keywords=convert+120V+to+220.
Look for words like "voltage converter", "voltage transformer" and "travel"
How do you change the voltage of a tv
The voltage that a set uses for power cannot be changed in most cases--if the set uses 110-120 Volts for power and you want to use it somewhere with say 220 volts--you buy a step down transformer which will convert it down to the lower voltage---if going from a source of 110-120 to a 220 source you buy a step up transformer.
6helpful
2answers
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
1helpful
Hi .. am in a country that has 220V power outlets. What do I need to use my kitchen ais that has 120V, 60hz and a maximum of 330 Watts requirements?
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
We have a Sony Bravia 2 years old from USA (110 vault) and have now moved to Singapore (220 vault). Can we plug this tv in or do we need a transformer?
you would need a step-down transformer from 220 volts to 110 volts. Also you need to consider the Frequency as USA uses 110-115V 60Hz and many countries around the world use 220-240V 50Hz. In addition you need a physical wall plug adapter so you can plug the power cord into the wall. These are not very expensive but get the proper kind. Generally it is a good idea to buy a TV over there which is more compatible.
I bought a ps3 in US and plan on bringing it to Chile. Voltage and frequency for Chile is 220/50Hz. Will the US unit work?
no, the games are locked to region - a chilean game will not work in a US playstation. the electricity problem can be solved with a transformer.
Voltage: own a 220 volt Series 3 330 shaver , now in Canada 110 v
You can try dryer power port, it's 220V, and you have to buy a adapter to replace the port on the wall accord with your Braun, or to buy a transformer (110 - 220).
2answers
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
