Check for loose wires between the clock Movement and the chime box. If those are good (and the batteries have good solid connection-not lose) you probably need to replace the chime control box or the whole movement.
Timesavers.com carries replacements.
Mechanical clocks, while more in cost, will live a much longer life with proper care than battery clocks. Plus, an actual chime (not noise through a speaker) is much more pleasing to the ears.
Hi, this second wire is a permanent live feed for inside the car, the things it runs are things like the stereo all its their for is so the stereo dont lose any stations that you have stored into the memory other than that their isnt much else it runs, maybe the clock, you could check by seeing what isnt working when the key is out, check the clock and stereo, if the stereo works with the key out then it must have its own live feed.
the chances are it wont work and you will lose the preset saved stations.
i hope that has given you some idea of what its for.
please let me know if you need further assistance.
plz can you rate this post as i have pages of unrated posts, thanks
Seems like you have a bad ground connection..Check that the wires are all tight and clean from the battery to the engine, and from the engine to the body of the car.Good luck
This is a common problem among on some of the Japanese automobiles (Hyundai may be included) that have seen some time in service.The
clock module becomes intermittent or dead after a few years of service.
To remove the clock yourself and have it professionally repaired, you
can contact Dr. Clock at www.subaru-clock.com for a speedy fix.
To resolve the issue you are facing with you need to check the following parts—
1.Battery voltage at window switch. If no battery voltage at that switch, check for broken wire between door and body it means the motor of the window has gone bad.
2.If window can be operated by driver switch or individual switch it means window switch has gone bad.
3.If the pin connectors are broken then it means the switch connector of the window has become unserviceable and need replacement. If none of the non-driver switch is working then it is a bad lockout switch.
Please check all the above possibilities and repair/replace whatever is gone bad.
I had similar problem in 2001 rx300. Every morning the clock
will reset to 1:00. Sometime this will happen when I started the engine. The Lexus dealership replaced the car battery. According to the mechanic, The Rx300 are very current sensitive system and even though The existing battery was 3 years old the cold weather made the current go below the allowed limit. That makes the clock reset to 1:00. After replacing the Car battery, the problem when away
Does your car have an automatic raising and lowering antenna? If it does check your fuses for it. If not pull your radio out of the dash, and check to make sure that the antenna wire has not become lose or unplugged from the back.
This is a sure sign that your CMOS battery needs replacing, but you may need to take to a qualified repairer as the battery can be hard to access or even locate.
