Make sure that you have turned on the tv before you begin programing your Uverse remote control.
Hold down the TV button on the Uverse remote. (If you are trying to program a different device, hold down the button that names that device). As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
Find the 4 digit code for your device
At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. The manufacturer of your TV has many codes.
If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter.----------------------------------------------
Sharp TV codes for at&t remote:
1004, 1009, 1011, 1025, 1064, 1077,
1078, 1081, 1097, 1099, 1153, 1157,
1274, 1298, 1311, 1312, 1362, 1375, 1378
