KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IT HAS STOPPED HEATING. WHAT CAN I REPLACE TO FIX THE PROBLEM
Anonymous
Level 3:
  • KitchenAid Master 43,501 Answers
  • Posted on Jan 24, 2011
Anonymous
KitchenAid Master
Level 3:
Answers
43501
Questions
0
Helped
10835177
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Whirlpool gold microwave model gh6208xrs stopped heating
As a service tech do not attempt to service a MW call a professional or replace there are components within that raise voltage from 120VAC to upwards of 5000VDC leave it alone call a pro
1helpful
The dryer is heating but the drum has stopped revolving what could the problem be and is it simple to fix.
Your dryer may have broken its belt, or the motor may have died.
A broken belt is "easy" to fix (if you've done a few), and not too expensive (if you do it yourself).
Replacing a motor is a little more involved (the drum has to be removed), and very expensive when
doing it yourself, and if you're not going to replace the motor yourself, it may be more cost-effective to replace the appliance rather than pay a technician to replace the motor.
A major appliance (dryer/washer) should last 10-11 years.
My microwave has stopped heating up! model #721.80043700 anybody having this problem? Do you know how to fix it?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytu53w
My microwave has stopped heating up! model #721.80043700, anybody having this problem? Do you know how to fix it?
My microwave has stopped heating up! model # NN-S540BFW PANASONIC ANYONE ELSE HAVING THIS PROBLEM? DO YOU KNOW HOW TO FIX IT?
Built-in microwave stopped heating repair or replace
Hi, Replace...
heatman101
Stopped heating
The microwave chip has failed. It will likely cost up to $100 to fix it, I would recommend a new one
3helpful
2answers
Stopped heating
Ok, if the fan and everything else is functional, this will point directly to a failed Magnetron assembly. this device is responsible for the heating process and, if it is not working properly, your microwave will not heat. Simply replacing the Magnetron will fix this issue.
The microwave stopped heating. Everything else is working fine.
Ok, concerning the heating issue. you will need to replace the Magnetron to restore the heating feature in this unit. this device is damaged.
Concerning the motor(circulation). If the motor is not working, this will damaged the Magnetron, due to poor circulation. i recommend replacing the motor asap.
In conclusion, you will need to replace the Magnetron and the circulation motor as well. replacing these two vital devices will fix your issues. the total cost for these parts are estimated at $87.90
2helpful
Microwave not heating
The Magnetron has stopped working in this case and, you will need a replacement Magnetron heating device. this will fix your heating issue.
Replace the Magnetron. Runs about a 160.00 or maybe cheaper in most cases.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
