Bosch WFG 2020. It's a fab machine, but yesterday it did this and I can't get it to drain or spin. I had to manually drain it with a cup. Then I put another load it. I washes a treat, but same thing. Won't drain or spin. Even if I stop it and put it on spin cycle.
Alas, what to do. Buy a cheap spinner? I like the machine.
April
Sir,
Common problem with this otherwise tragically flawed washer: it will tumble and pump out the water in the tub, but it will not spin. Usually, the problem is the speed control board. However, in accordance with the Ichiban Law of the Prophecy, you should use your meter and do a few tests to prove that the board is bad or not?
Call your nearest customer service centre for replacement of the Speed control board or check with the Speed control board is working or not. ok
Thanks
Good luck
Don't forget to rate the solution
Does the unit start atleast? does any humming sound come from unit?
If there is a drain issue, sometimes there is an obvious
solution.
Check the drain hose for any kinks, as well as checking any lint
filters in or on the drain hose. Is there a lint sock on the end that's
full? Perhaps the drain line itself is plugged. You will want to make
sure that the house drain system is not backed up or plugged. Always
make sure that the washer drain hose is above the level of water in the
drain tub.
If you think your pump may be jammed, drain out your tub and
remove
the hoses. Look inside the hoses and see if there are any obstructions.
Feel around inside the pump inlets for anything that may be jamming the
pump itself. You can also use long-nosed pliers to feel around inside
the pump for any items that may be causing a jam. If you haven't found
a jam, and you still believe there may be a jam in the pump, you can
completely remove the pump from the washer and inspect it more closely.
thank you
dont forget to accept the solution
have a great day
Yes it will start from the beginning of a cycle, and there is no sound which is unusual.
It just won't drain or spin. April
Thanks for all this. I will check it and get back to you!! A
Not sure how to test this. It has pumped out the water actually. It wouldn't either drain or spin.
Alas
no suds from machine
