Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Mine are bad...........But I moisten them before I seal.....works fine
There is a pressure switch (looks like a flat red barrel) attached to the circuit board. When it senses the correct amount of vacuum, it triggers the sealing process to start. If this switch is not working for any reason, the vacuum process never stops.
On mine, one of the solder joints on one of the switch legs went bad, and one side of the switch wasn't connected to the board anymore. I resoldered both legs, and the sealer works again.
vacuum motor works fine
