Bosch Axxis WFL 2060 Front Load Washer mould on door
gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
That is a very common issue,, there is not a good way to remove it just alot of cleaner and time,,,the other wat is to replace the gasket, ( about 150 for the part and alot of time and headache to replace) to keep it from doing it again you will have to leave the door open when your not using it, and get some cleaning tablets to run through it
SOURCE: rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
SOURCE: replacing door seal rubber boot
Hi its just a peice of wire with a spring tensioner just pull the door seal free" towards side of machine not forward" it will come .....then you will see wire ! you will kick yourself when you see.... it i did lol
Tommy-B-
SOURCE: leaking door due to the wire ring that holds rubber seal
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
SOURCE: The rubber seal at the front of the machine has
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use
powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door
open to allow it to dry. .
