Question about Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne
My eletrolux ergorapido will not hold its charge. Can't find a new battery. Where to I go to get one?
  • Don Richards May 28, 2012
    I ended up putting 9 of the 10 batteries and it works great. Much better than orriginal batt and laast much longe batterr lifer with kisk but speed . Love my toy. Wish I had hooked ut the 10th batterry now and there is room if you play wyrh the wires just rirht.
    Hanger
    New Friend:
You can get new battery from amazon. Take a look here Replacement Battery Pack for Electrolux Ergorapido 2 in 1 Stick and... , that was cheapest (with good reviews). I hope this was helpful. cheers
Posted on Nov 25, 2014
  • 2,418 Answers
Let me say this; The battery replacement for the PRONTO is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work.
Posted on Jan 27, 2011
6ya staff
SOURCE:
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 | Vacuums
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a 2 year old Electrolux ergorapido cleaner that gets used daily for about 2/3 min, the blue light on the stand comes on when the cleaner is put on to charge but fades after about 5 min & the...
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Jan 21, 2011 | Electrolux Vacuums
Do i keep my ergorapido charged all the time when not in use?thank you
you can if you want to but in order to get the best of it when useing it you should keep charged
Dec 29, 2009 | Electrolux Vacuums
My electrolux ergorapido wont power on . Have only used it a few times. It has been on the charger for approximately 2 weeks without use.
If it will not come on there are several things you need to check. First off you should call and have your model type and serial number checked to be sure your unit isnt affected by the recall they had due to expanding batteries. Second you do have a 2 year warranty on the unit and if it wont even turn on there may be a defect. Are the blue charging lights coming on? If they are and your transformer is warm then there is more then likely a defective battery in the unit and you should contact customer service at 1800-896-9756
Jul 18, 2009 | Black & Decker AV1200 DustBuster Handheld...
Ergorapido: light doesn't come on when vacuum is put on charge
If it is new, take it back and get a different one, either the charger or the battery is bad.
Mar 26, 2008 | Vacuums
Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne Logo
8,995 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
gggg
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
