seems that your TV have a bad T-CON board, you have to take it apart and check for the exact part number on the board, because those sets have different version of those boards.
to give u an idea after you take it apart look at the top of the screen for a part like this :
My Colby power button and volume controls quit working. After taking it apart I found behind the buttons are printind circuits. I didn't need to take it apart. I used an exacto knife and peeled up the adhevsive front around the buttons. I used a small screw driver to hold the front apart from the tv. I used some tin foil and placed under the button. Too much tin foil makes a constant contact which you don't want. You just want enough tin foil when you press the button it makes contact with the printed circuit. Test your buttons. If fixed, press adhesive front back against the tv body.
unless your very savy no. I have taken apart tv's monitors and found the swollen capacitors and replaced them. Sometimes though its not that and then you have a tv ripped apart but what have you got to loose if its already not working
Disconnect power and then re-apply. If the disc doesn't come out, then the drive either has a bad drive belt or the eject motor is bad - it'll need to be taken apart to fix.
when the green blinking light won't stop you have a bad dm module, it's about $800 just for the part. you could take it apart and try changing the big 1000 micrfarad at 16v capacitors on the dm board, but this almost never works on dlp's, and taking this tv apart to fix it is a major job, you need alot of money and a tv repairman to fix this.
