To transfer the recordings from your Samsung SC D353 Mini DV tape to your computer, you'll need to follow these steps:
1. Connect the camcorder to your computer: Use a FireWire (also called IEEE 1394) cable to connect your Samsung SC D353 Mini DV camcorder to your computer. Most computers have a FireWire port, but if yours doesn't, you can purchase a FireWire adapter card. 2. Turn on the camcorder: Turn on your Samsung camcorder and set it to VCR mode. 3. Open the video capture software: On your computer, open the video capture software that came with your operating system (e.g. Windows Movie Maker, iMovie on Mac) or a third-party video capture software (e.g. Adobe Premiere Pro, Final Cut Pro) that supports Mini DV tape. 4. Start recording: In the video capture software, select the option to capture video from a DV device. Click the Record button in the software and then press Play on the camcorder to begin playing the Mini DV tape. The video should be captured and recorded onto your computer. 5. Save the video: Once the video has been captured, you can edit it if necessary and then save it to your computer in the desired format.
Note: If you do not have the original video capture software, it is recommended that you search and download compatible software before beginning the transfer process. Additionally, make sure your computer has enough storage to store the transferred files.
i had this problem la port 1934 is active ? it`s been my first problem second my problem to many USB conected so virtual memory problem :):). . I used program PowerDVD after that no more problem and im hapy i hope you will try. CIAO
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer.
Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board.
You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer.
Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer.
If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software.
You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site.
Making the connection
Connect the camcorder to the computer as shown in the figure below.
The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used.
Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal.
Precautions
(1) There are cases where the connection may not work correctly, depending on your system specifications/settings.
(2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions.
(2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer.
(2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable.
(3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
