If you forgot the windows password, you can use Windows Password Buster to reset the password.
Flip the machine over and find a small hole about 1in. diagonally from the right lower corner of the data plate. Insert the tip of a tooth pick into the hole and press down for about 10 second, with the AC power connected to the machine. It should re-load a fresh copy of the operating system
You may find TIP found at: http://www.fixya.com/support/r7957741-sy... useful.
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
SOURCE: I can't remember my administrative
TRY TO BOOT IN SAFE MODE IF POSSIBLE OR THERE SHOULD BE A RESET BUTTON ON THE PC TRY THAT BUT BE CAREFULL U MAY LOOSE ALL UR DATA ON THE PC
