I have record with my JVC GR-D70EK max 120minutes of material and LENS CAP sign aphears on screan every time I try to use this product.I have record with my JVC GR-D70EK max 120minutes of material and LENS CAP sign aphears on screan every time I try to use this product.
You can't post conmments that contain an email address.
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Knowledge Article
C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
Follow
this procedure to troubleshoot if there is no picture or a black screen
NOTES:
Because
each of these steps represents a possible solution to this issue, check
the viewfinder or LCD status after completing each step.
It
may be necessary to refer to the operating instructions provided with
the camcorder for information on how to perform a task on your specific
model.
Ensure the lens cap on the front of the camcorder has been removed.
Ensure a fully-charged battery is inserted in the camcorder.
Ensure the STANDBY/LOCK switch is set to the STANDBY position.
Turn on the camcorder and set it to the CAMERA mode.
Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT:
Some camcorders have both a viewfinder and LCD. To conserve power, the
viewfinder and LCD will not display at the same time. To use the
viewfinder, the LCD must be closed.
If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
