Question about Gigabyte GA-8IG Motherboard
Sir I am Nitin from Firozabad. I am using gigabyte motherboard. I am trying to connect pen drive but my computer giving a message "Usb not recognized" but my idea net setter is connecting and i have a refresh problem when i refresh my computer by F5 key all Icon is Ups and down while i refreshing my computer please solve this problem.
  • Idea Cellular
    Idea Cellular Feb 02, 2011
    Dear Sir,
    Kindly provide your Idea cellular number for further assistance. You can also get in touch with our Customer care centre - details updated on Idea website. www.ideacellular.com.
    Regards,
    Ideacellular
    Habit-Forming:
    New Friend:
  • 55 Answers
A virus is running to your system . scan it , if not work , just reply
Posted on May 30, 2018
6ya staff
SOURCE:
pagebor
Rajkumar Bordoloi
  • 2785 Answers
SOURCE: Gigabyte GA-8LD533 Motherboard driver not found
plz check the following website
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1402
Posted on Jun 13, 2008
smilemaker
Kanth raj
  • 790 Answers
SOURCE: USB drive is not working - Drivers are installed.
Hello!!!
  Is it a new PC ?? if so guess u havent connected the USB drive slot  to motherboard. If not try other slots too.. later let me know!!
Regards, Smilemaker
Posted on Sep 03, 2008
Anonymous
  • 763 Answers
SOURCE: how to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
from your case there are wires to put it on the motherboards pin. you can check your motherboard's manual on where to insert the designated wires to the correct pins.
thank you for using fixya
CHARCOIS
Posted on Nov 10, 2008
laikexpert
laikexpert
  • 281 Answers
SOURCE: pen drive not working
2) How to put Slax on CD:
http://www.fixya.com/support/r3879348-slax_guide_survival_live_linux_usb_flash
Posted on Feb 02, 2010
Forixx
Bebe Perez
  • 78 Answers
SOURCE: enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
Posted on Mar 30, 2010
How to install windows 7 32 bit in my gigabyte 8vm533m rz motherboard
You need the installation DVD, or download the ISO and copy to a bootable USB pen drive.
Boot from the DVD or pen drive and follow the on screen instructions.
You will need the licence key to activate the software.
Nov 13, 2013 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Sir when I plug in my pen drive and try to access it, the comouter shows a message "access is denied".Please give me the solution to fix the problem
Delete the autorun.inf file on the drive.You may have to set your computer to show hidden files and system files to see that file.
Mar 01, 2011 | Computers & Internet
Hellow sir, I am mahesh. I have transcend 4GB pen drive (JF V10). My problem is, When i connected pen drive to my pc then it could not start but it was shown in my computer as a removable disk and...
its just simple MAHESH...
1st if your pen drive has no data inside.. don't hesitate to reformat it.. then try again..
2nd check the device manager on your computer if the pen drive of yours was updated with its USB port.. just look for the UNKNOWN DEVICE in the USB port in the bottom of the device manager..
if there's no name of UNKNOWN DEVICE it means you must go to the settings of your pen drive..
just right click your pen drive then properties,, then look for the AUTO PLAY then select the action to perform..
then apply and ok... now close all documents then go to my computer and right click your pen drive and click the AUTO PLAY if its work... restart your pc... then its done... ^_^
Oct 18, 2010 | Computers & Internet
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
I can not access data on pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 29, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hi I m using Gigabyte GA-8I845GVM-RZ Motherboard USB drive is not working, printer, data cable, pen drive everying is not working but all the drivers are installed properly. Advise please. Arul selvan. M
Sep 03, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : safiqul.alam@gmail.com
Mar 25, 2008 | Electronics - Others
Gigabyte GA-8IG Motherboard Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Ekse
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
